Door Question
Daniel Scully
Door question. There are vacuum lines to the suicide doors on the 62. There is a switch with a indicator light under the left side of the dash. Thinking these are lockout for the suicide doors? Have not pulled the door panels to see if there are vacuum cans there. Thanks20250511_192401.jpg68ae463e-634b-444a-9819-f4f7617fbb6f.jpeg89e56cb5-259e-4f9c-a81d-dc6743a64eed.jpeg
Rather than pull the door panel off, I just put a vacuum pump on the lines. With vacuum one pulled the lock knob down and the other pushes it back up, so locked / unlocked. The lines disappear somewhere in the body up to the dash switch. It appears to be factory as the line clips have white paint under the blue when it was repainted from white to blue. The plan was to install new carpet, and I noticed these on the bottom hinge.
