As you may know, I had the 67's radiator fixed and all of the radiator hoses replaced in the engine compartment. The next step in the project was to have the rear heater looked at and replace the hoses that connects it to the main radiator.
Last weekend, I removed all of the hoses and took the rear heater core to the radiator shop. They cleaned it up and am ready to put it back in the car.
I also repaired the fresh air intake assembly. The only thing missing is the heater motor that should be repaired within the ext 2 weeks.
The next steep is to run the hoses from the back to the front. Where the hoses transition from the wheel well area to under the car, they are joined by coper pipes that go through at 90 degrees elbow through the floor.
I also want to replace these coper pipes, so my question is does the regular led that one would use soldering withstand the heat of the hot engine water?
If not, what would you suggest that I use to solder these pipes together?
Thanks,
Thanks,
