Mike Stevens
My coach has a CB antenna on the roof. I don't use the CB. The bottom of the mount where the coax cable fastens is beveled. It has several serations cut into it. It looks like the beveled/tappered stem fits through a flat washer. What is the trick or tool needed to pinch this tappered area so it will pull out of the flat washer so we can remove the antenna? I have never seen an antenna mount of this design. I went looking for a nut on the bottom inside the roof and did not find it. If it had been a normal mount it would be gone by now.
I want to get rid of the antenna and put my Federal beacon in place.
Thanks for any tips here.
