Having a problem with a carter AFB carb. The carb wond idle. Think its an internal vacuum leak. When I rebuilt the carb, the prev owner had adjusted the fast idle cam so the car would idle on the fast idle cam. When I correctly adjusted the linkages, the car would not idle. Pulled the plugs out to inspect the idle circuit ports, and they were clean.
I dont see any cracks at the vacuum ports. Anyone ever come across this?
