bumpers
got to taking apart this 76 bumper i have. set it up agents the 68. yes they are the same centers. one just has holes cut in it were the other one does not.
from memory, it is the same all the way back to 1965, and forward to 1976 with the only exception being cut outs for lighting.
it looks that way to me. were there is some miner changes in the brackets on the reverse side. the stamp is the same. the big change came in the 70's models when gm mounted the center to the frame. the earlier ones mount off the bumper ends. if one were to be going to re-plate them changing the mount would be easy. as would cutting the holes for the 74-76. bending the tabs to mount the 71-73 back up lights might be a challenge.
