Back up light lens for '73 MM Lifeliner
Bill Leverett
Can anyone point me in the direction of a source for replacement back up light lenses for my '73 MM Lifeliner? They are Guide lights model number
68 SAE R71A. I'm sure they are/were a standard GM product.
I've done many searches and nothing comes up close.
Thanks.
Thanks.
Why not post a picture?
That's it.
Thanks Daniel for posting a pic. That is indeed the lens I'm looking for...actually 2 of them if possible.
same. they used that light in all the cut out bumpers. 70 to 73. so we know it's a standard light out of something else GM made. what is it. license plate light or back up out of what. I don't see GM tooling for a light if they had one they could just make the bumper fit and add the plastic surround bezel. if they had made one it would have fit the bumper better.
the number suggested it's a 68 light.
John the bezel is die cast, here is a pic of all the pieces involved on a 72.
1968 Camaro Lens?
Well, I have found these that seem very close although the Guide number is not the same. They're from a 1968 Camaro.
Does anyone have a Guide brand catalogue?
they look close. just not as deep a box. one would have to compare them side by side to see if it could be used. the housings are differnt. a old gm parts book is what you need to look up the number. gm was big on adding a tab or a knock out and changing numbers. so who know what what could fit. I swear that the 71 superior I had was plastic on the Bezel. it was pealing chrome anyway. but that's been a while ago. like everything else on these cars it's subject to change from one year to the next.
Thankes Ed. I'm just looking for replacement lenses at this point. Mine are OK for now but have distorted over the years due to heat it seems so they'd look better replaced.
GM number and use
OK...I found that there is another number on the lens...5964519. Apparently these back-up light lenses were used for all 1970 Cadillacs except for the Eldorado and 1971 to 1973 CC Cadillacs.
No other use by GM apparantly so finding them on another vehicle may be tough.
