John Burchfield
PCS Life Member
While some of you were having fun in Piqua, I managed to get some car projects done. My '65 Superior combination hadn't been out in a few years due to a gas tank issue (see post in Technical forum) but I finally got that repaired, battery charged/replaced/charged and got her started up! The '69 M-M needed to get out first-it hadn't been out in a couple of months, so that doesn't qualify as an "awakening"! Both cars started up quite easily with a little gas poured down the carbs. It was especially nice to get the '65 going again. Her brakes are a bit mushy-I filled the master cylinder before starting. I'll have to check to see if the power booster has gone bad or (hopefully) it's just a matter of air in the lines. There was enough brake for a short spin around the neighborhood. Surprisingly little smoke after such a hibernation, too!
