Mike Stevens
Okay, it is my turn to ask the experts. Like Joe Friday used to say, "just the facts".
My coach is a 1961 M-M limo style. It has 87k miles on it. It lives in the barn most of the time. Never sits out unless it is at a meet or show. Everything was working just fine. Never any problems.
While on the way to the barn last week the turn signals went out. So did the brake lights. I found a burnt fuse. This car has the round glass tube Buss fuses. For some reason the 15 amp fuses do not fit into the Cadillac fuse box. Too long. Maybe a few thousanths too long. I got everything working again. I used a 14 amp fuse that was the correct length to fit in the box. All is fine until I set the turn signal lever for a right turn. The flasher (new) will tick once or twice and quit. If the flasher clicks more that once the pattern is very fast. The fuse blows. I have tried other new flashers. What came out was a #552 Sylvania flasher. The old flasher was marked for 4-6 bulbs. There are 6 bulbs in my system. After 3 burned fuses I took all the bulbs out and checked for continuity. All was good. Everything looks clean in the sockets. The bulb bases are clean. Is this an all of a sudden bad ground, a rubbed wire, or a bad contact point in the system? The fuse only burns out when the right side turn signal lights are activated. The turn lever seems to have no difference in feel when you set it for a left or right turn. So experts where do you suggest I look next?
Thank you for your suggestions,
