Anyone know this hearse?
I know that hearse
Chris,
This hearse showed up at the 2008 Spring Grove Cemetery car show in Cincinnati, Ohio. If you look at the picture you will see other procars in the backround. If you go through the photo stream this hearse is in you will see my
61 M-M limo style combination is parked in front of the questioned hearse.
Rear Door
It is a noteworthy S&S Victoria right off the bat due to the RH hinged rear door. I like the mint green interior much better than the "wild green" interior pattern commonly found in mid '70s S&S coaches!
