Don't forget that one is patterned clear threw it. It Olds look worse then that. You can sand it down to bring that appearance back won't bring the deep scratches out or replace missing places. But the scuff or discolored places will surprise you how much better it looks. Start out with 80 grit work up to 400. Then sealer and wax. Buff it with a a gray scotch pad, re-wax And buff with a buffer pad. Take the trim off polish the put it back on for the second wax. A lot of work. But you will need to do all but the sanding with new flooring anyway. With new you start with the gray pad. I done miles of it working house keeping.
