A/C Compressor
I think the bearing is starting to go on my A/C compressor, so it will need a little TLC.
Since I am there, and that the unit seems to be original, it may be worthwhile to do more than change the bearings. What do you guys recomment? Have it rebuilt, trade it in for a rebuilt one, replace with a new one?
Thoughts?
Send it to Classic Air in Tampa, Florida, and have it rebuilt. If you have the tools, you can change the bearing, but it will be easier to replace it off the car than on the car. There is a slight difference in the mounting bolt patterns from year to year. If you are replacing the front bearing, you should also replace the front seal and the oil wick located inside the bearing cavity. If the system has lost its refrigerant, then it will need to be evacuated and recharged. If it has been converted to R134 instead of the original R12, some other parts should be replaced to improve the unit's performance. I prefer to use R12 whenever doing refrigeration work on old cars, since it works better than the modern refrigerants. The molecules in modern gases are smaller than those of R12, and as a result, some refrigerant loss is to be expected through the old hoses. Another item is the old butyl rubber O-rings, which should be replaced with Viton O-rings if you are going to do a complete servicing of the unit. As you can see, it is easy to go down this rabbit hole, and you will spend a lot of money and time before you see light at the end of the tunnel. I did my 1962 a couple of years ago using all original parts, and it works excellently.
it would depend on what bearing you talking about the one on the clutch or the compressor itself. the Pully barring is the most used as it runs all the time. any shop could change it.
Had to take the car to the shop for something else and got them to try to locate the noise for sure. They removed the belts one at a time to identify where the noise was coming from, and the issue originates from the generator, not the AC compressor.
Terminology is important. You have an alternator on that vehicle, not a generator. Ask them to verify that they have the parts available before they disassemble it, as many repair parts for that alternator are no longer available. Most likely, the bearing is still available, but I know that diodes and some other parts are not.
I sent them the info on Friday and he will look it up.
The alternator is at the shop to get the bearing replaces, cleaned-up and tested. I will get it back early next week. I also have an appointment at the end of the month to replace the A/C compressor with a new one. Hopefully this is it for this year!
