Bill Leverett
I know the collective wisdom will help me with this. Pictured are the nylon clips that hold the stainless trim on my Lifeliner.
When I removed the trim, the majority of the plastic tabs on these holders broke off (very small plastic tabs at the top and bottom). If I try and remove the clips, the round nylon center piece stays and the remainder of the clip comes off. I'm guessing that this is a proper design feature so that the remaining round plastic piece can simply be pushed through the panel and fall off inside. This leaves a nice hole to use a brand new clip.
The part number on the clip is "P-4268". It is 1 3/4" in height.
Has anyone run across these before? Are replacements available and if so where? If not, what should I use?
Thanks
Thanks
