I have a friend with a 68 MM hearse. Her turn indicator on the driver fender does not blink. How do you change out the bulb? Does she have to remove the headlight assembly and get to it from there?
not responsible for runs and thin areas.as the 66
I think I'll keep that trick for future reference I may need it.
.............. buy a book. then read it as some old grouch says.
thanks did they have a couple of the them push on retainers on the rear posts sticking down there? that was usually GMs idea. that way you could feel moment and think you could pry it up. thus braking off the stud requiring you to go get a new one.
