May 13 2010 Update
I left the 67 at the body shop this morning. The plan is to take a hard look at the body and the paint to determine if we need a full strip down to metal and paint the car type job, or can we look at fixing what we can find and go from there. There was a new paint job on the car probably 4 years ago, so there may not be that much to do.
Over the last couple of months, I have removed as much of the trim as I could and in the process found out quite a few spots where water was coming in. All of the trim around the rear side and rear corner windows have been allowing water to come in, and by the amount of rust that can be found in some areas, I’d say that it has been leaking for 40 years. On the good side, all of the window rubber is still in great shape. The water was coming in from around the trim pieces, not from the window rubber.
The issue with the leaky windshield has also been found. There is a gap between where the fibreglass roof meets the metal above the driver side driver door which allowed water to come in, follow a metal channel and come out about 3 feet further behind the windshield. This gap was behind the trim that is above the drip rail.
In order to remove some of the trim pieces, I had to detach part of the headliner. This was relatively easy for most of the car because it was held in place by staples and wood strips. The hard part was the removal of the headliner sections that is above the 4 side doors because it is held in place with a metal say tooth strips. I used a tip from John Renstrom and was able to take care of it relatively easy. Thanks John.
I also found 2 of the risers that hold the bumper and even maybe the rear sill that are compromised because of rust plus a section of the riser that hold the rear door with a big hole into it. These will all have to be replaced.
Other odds and ends include the replacement of the mirrors on the driver and passenger side doors. The ones currently on the car are rectangular, the originals were round. The Pontiac logo on the nose of the car will be replaced, the rear side windows will be sent to the sign shop to replace the graphics, the leaky power steering will be fixed, electronics will replace the old points, and because of the cost of it all, we will not be finishing the basement this year.
This just to say that just because a car looks good, it does not mean that there is no work left to do on it, and at the end of the day, if you would have seen the car last year and compare it to what you would see when it comes out of the shop, you could probably not see any difference.
