Philip Scanio
PCS Member / Super Site Supporter
What happened to that Ford?
do we put in every other one with a different head or trade then all?
I remembered. I was wondering how you painted the door jams?A couple of things that I noticed. The rubber hose connecting to the breather on the valve cover is bent over, so the engine can't breathe properly. If you post a picture of the clips that you need, I might have some. Do you have the rubber that goes into the roof molding? I had some that I got from the late Tom Caserta. I don't remember where he got it, but I never got around to installing it on the roof when I owned the car. When the weather gets warmer, I will see if I can find it in the garage. There was another item, however, I can't remember what it was, but with any luck, I will remember tomorrow.
I got to stop doing this late at night I forgot to hit post my note last night. but be that as it may we did stuff any way worked at the script and louvers replaces the gas cap it sure looks better with the glass cleaned. stepped out on the porch and found this big roll. the much-awaited flooring has arrived. we can get the car on it wheels and move it forward enough to open the back door and get it in place. soon. someone had used a set of the square screw plastic screw holders to attach the lovers before so that all we could come up with to do it now. took a while to find the ones that work but fined them, we did. they grep the post as good as the barrel nuts do. found one with the post broke off and lost another in storage so we had to make a post for them. got the hole drilled found a screw that would fit in and added a drop of super glue in the hole before we put it in. then cut the head off and formed the post. you can do that easy enough on the thick ones![]()
