62
Daniel Scully
Looks like it will clean up pretty good. Table now works as it should .Having some bushings made for the table and should make new hyd hoses for the Lev -L -Matic as they run under the floor to the back cylinders.
lot of work getting it cleaned up and lubed but will worth the effort. most of the cars are passed on because people can't do it them selves and there are few repair shops that will either. but it looks to be a nice car will kept with out the other problems one has to fight beside the normal maintenance that has not been done. had to see one still with the factory primer on the cab floor. ace has a vinyl repair glue that does a good job of putting the small tears back to gather. may be able to save you from father damage and keep the panels original.
John, I will chk that glue out Thanks. Pretty amazing something this old for even in So Cal to be virtually rust free.
