'60 Miller Meteor landau
Apology up front if double post. Extensive search didn't turn it up~
Started out as a picture texted from a buddy in a Western junkyard in late '11:
He isn't a hearse guy - but he is a Cadillac collector. I look out for his interests and he reciprocates.
This '60 is truly a book example of collectors' interests traversing full circle. Way off beaten path, higher elevation, not in an area of the US known for rust>>>>>>>Yes, those are Rockies in background.
Even with all the glass broken out metal looks like a decent (although incomplete) builder. And of course, it looks a 3-way. Over the next month or so a few more shots trickled in, along with a (fair) price. Still no contact number though, that took awhile longer.
Finding that rear loading door glass would be key. Table non-inclusive (if it was a 3-way) that '59-'62 MM glass piece is hardest part to find!
Last month I located that glass before emailing/calling a few friends to see who was looking for a project of this vintage... Then a different friend saw these pics for the first time and mentioned having a really rotted but complete '60 MM 3-way. (Unknown to me as stored in a different state.) His even has all good glass; his interest in possibly acquiring this white one piqued.
What turned out being an arduous process then began trying to confirm 3-way status. Getting someone physically there to inspect coach; then having person go, not have cell reception, and forgetting what to check out. Get the idea?
Among next set of inspection pictures:
Can't clearly see tops or bottoms of interior B pillars. Pfft.
Relayed at this point that floor had been recovered (no roller holes or table tracks), also meaning rear interior definitely isn't stock fabric. (Although Stanley and Helen Roper would have no doubt approved. ;)) Side doors were not opened. Argh. If a partition had been removed, the rear floor was extended to the exact length of a 3-way table - a good sign. Other good signs include no rollers in rear loading door sill and no exterior door locks on second side door set.
Then finally - success! Next trip proved 3-way. Finally. B pillars attached to rear side doors. Last shot I want to share is pretty damn neat. Check it out - factory white crinkle top. Never seen any light colored crinkle top before.
Missed that detail in original captures.
So it took a few months but it looks like this 3-way will finally go to a deserved home and ultimately return to the road as it left the factory. :thumb:
Great find, glad to hear someone is going to fix it. Im supprised to see the headliner still intact and it looks good in the pics.
One trick I learned by another member years ago that helps confirm a 3 way from interior pics (if you are not sure, I know in this case it got confirmed in the end) is to look at the B pillars from a few inches above where the table should be to about the middle of the glass for the lever end that the handle attaches to. I have confirmed many old pics by this method and was very glad to learn of this little bit of info. As far as I have ever seen all 3 ways use this inner handle and the outer is fake, if someone has seen an outer handle work I would like to know.
Correct Scott.
As one can see in provided shots, enough interior B pillar covering and hardware had been removed/altered to negate confirming 3-way via that route.
This all original coach is what it should have looked like:
Confirming from lack of cabnits is harder than just checking the posts for handle hardware, as some coaches were ordered without partitions. on the pic from the front door you can clearly see it, and the shot from the back you can clearly see the tabs that the handle attach to stick out on each side.
Atti, do you have any more shots of the as new car? I would like to see more of that beauty.
I think all the early ones are but the 78 I have it takes both handles inside and out to unlock the side door,
