If it were closer, more complete, and better priced, I might consider it. Too many parts are missing to even consider it as a parts car. Good chance that the engine, transmission, brakes, will need a complete rebuild. The most valuable part of that car is the front group, and that is probably only worth about $1000 - $1500. You could easily spend $10,000 - $15,000 just to make it roadworthy, and then you still need to completely rebuild the camper end, which could be just about as much money, so after you spend $20,000 = $25,000, you still have a vehicle that is only worth about $10,000 - $15,000 at best.
