Yesterday, a friend of mine [who also is a body man with 30+ years experience] was telling me about a way to save some time and labor [and money for those of you that can't do the work, like me, because we lack the knowledge to do so] by using 2-part epoxy to bond patch panels to the vehicle body. He buys a large tube [read standard size that goes into a caulking gun] of epoxy at $50 per tube and then he applies the epoxy to the panel, the tube has a tip where both sides mix together as it's dispensed. Once it's been applied to the panel, you just clamp/screw the panel in place. After the set time has past for the epoxy, you just remove the clamps/screws and finish out the edges of the panel with a grinder and then do some light bodywork to blend it into the panel being repaired. The epoxy is waterproof and you won't have rust in that location ever again.... This will save you [or whomever is doing the work] hours of welding the patch(s) to the panel(s) and also the time grinding down the weld so it's smooth so light bodywork can be done to finish it out. Epoxy sets probably in 15-30 minutes where welding could take hours depending on the size of the patch panel.....PLUS the cost of the welding gases....just FYI....any questions, just post here or PM me....
