1969 Stoner Ambulance
got the center panel tied in place. had a little problem doing the bottom, this one buckled on me. nothing a small tug didn't bring back out but still. just the long run let it do that. if you would have used the wire feed it would have happened. I did finish up that GL of mud though have to get another one tomorrow. did some test fitting on the left rocker it looks like we can get a better joint then GM had. but I will need to loosen up that tab I glued down.IMG_3130.JPGIMG_3131.JPGIMG_3132.JPGIMG_3133.JPGIMG_3134.JPGIMG_3135.JPG
nice day today, 71 and sunshine. talking cooler next week so let's strike while the sun shines. we can get the front fenders out of the boxes and into some primer. if it's nice Sunday get the inside white. then still get our rust repaired. blocked out the center piece using the long board and 180 paper. the trick is if it mud work it down if you hit steel stop. it was fairly straight but see we had a small belly going in the center. normal you work both ends more than the center. they we were able to get the rocker in place. my joint was just a hair better then GMs but these rigs were not built for beauty. glad to get this task done. see if we can get the wheels sand plaster and at least into primer tomorrow. we had to drill a number of holes in the fenders to move them from custom to delux.IMG_3148.JPGIMG_3149.JPGIMG_3150.JPGIMG_3151.JPGIMG_3152.JPGIMG_3153.JPGIMG_3154.JPGIMG_3155.JPGIMG_3156.JPG
this time of the year it nice because something cool is coming so today is the day. we need to get the sand blasting done and the parts inside. picked up the materials some time ago so let's put them to use. going to lay out the big tarp to catch as much as we can the grass doesn't like the coal slag. we need to clean up the wheels there nasty 3 with mud dubbers nest on the inside. and the spar has been painted more than once. we will clean up the jams and tight places on the doors. of around any rust threw spots. the center door is the rough one and none of them around. after we got done, we painted the back side of the wheels to get that out of the way. then blew out the doors to keep from dragging in more dust. just getting ready in case. hate to try to do this if it turns nasty for a while. I did recover about 6 gl of material to run again. about one more run is all you can do before its powder used up 3 times that. see I missed the date when I had to switch cameras. we'll get right on that. only the one wheel had the scale on it broke it up with the needle scaler not pited deapIMG_3157.JPGIMG_3158.JPGIMG_3159.JPGIMG_3160.JPGIMG_3161.JPGIMG_3162.JPGIMG_3163.JPG
you can only play around so long then it back to work. time to get the wheels we sand blasted painted white. I took a picture of the rear springs on the stoner. they have fallen prey to extra weight and the elements. there should be space between the coils, there is not on either side for this one.
might be something to check on . mean time its make the wheels white and let them bask in the sunshine before I get them mounted.
Ed,
You mention "hot brazing" often. Can you explain what you mean?
Is stead of wielding with a steel rod in reality I'm glueing with brass. The advantage is it melts at a lower temperature. So there is less chance of wrapping your base metal as you don't heat it to the melting point. It is the best option for me at this point in my life. Since they installed a pace maker to keep my hart beating at a rate that keeps me from passing out I'm not allowed to electronic weld. Our i would be spot welding it with the wire feed. But the other advantage of brass is it doesn't rust. It is the process that was used when i started doing body work in the late 60s. So it was good then its still good enough today.
finally got the glass back in without losing the trim. I admit I cheated and glued the outer tips in the rubber. it worked! wrestled the hood off by pushing it to one side so I could control the drop. then slid it over agents the wall. dug out the 12 ga. drop cord they had run from the rear to the front for their battery tender and the mile of heater hose for the rear heater. they had plumbed it in Seares with the factory heater?? you can till it wasn't from a cold clime. that would not work a below 0. started stripping off the radiator support and inner fenders. got the easy one off. still working on the one with all the aftermarket stuff tied to it. i does looks to me like the temp control valve is stuck shut. and we have two vacuum lines dangling. both with the heater controls. one for the fresh air the other water valve. we see about redoing them later. IMG_3193.JPGIMG_3194.JPGIMG_3195.JPGIMG_3196.JPGIMG_3197.JPGIMG_3198.JPG
got a little mor off the rig did manage to remove the support without pulling the radiator that was good. had a little trouble getting the regulator off it had rubber mounts and they were in bad shape. we did hook the cab heater back up. I don't low why the hose was bypassing things, but we will find out, I'm sure. still can't figure out why people route thing the way they do the hose and wire routing looks like a spaghetti bowl. we will try to make it a bit more forward. both inner fenders had swelling rust the right is worse. same with the support mounts. had to heat up the right side to kill enough rust to remove it. did get the headlight adjuster and springs transferred to the new support without breaking them. we will need to do some checking this weekend for the broken parts I know now where a number of parts trucks are located. found a lot of thingsIMG_3199.JPGIMG_3200.JPGIMG_3201.JPGIMG_3202.JPGIMG_3203.JPGIMG_3204.JPGIMG_3205.JPGIMG_3206.JPGIMG_3207.JPGIMG_3208.JPG in rigs at times but this is the only time I found a steak knife under a radiator.
here are the last three I took today the rust I dumped out of the support getting the condenser off and the one mount frozen on the support. last proff I as least got one thing done today. hooked the heater back up. tomorrowIMG_3209.JPGIMG_3210.JPGIMG_3211.JPG we will get some bead blasting done and start painting some black
as promised, we got after the rusty black stuff today. need to push the rig back to get walk around room to do it. haven't used the cabinet in some time so a few house keeping things needed to be done first and midway. but we got the majority of the task done and one side painted got all the small stuff yet to do most will clean up on the wire wheel.IMG_3213.JPGIMG_3214.JPGIMG_3215.JPGIMG_3216.JPGIMG_3217.JPGIMG_3218.JPGIMG_3219.JPGIMG_3220.JPG
nice day after the fog burnt off so we decided to make a run over the iron Mt and Needles before the close them off for the winter. but did have tome to turn the parts over to get the other side when I got back home. got three more to blast and paint hope to pick up the other needed parts tomorrow. then we can start getting things back on. not hardly enough of the right support bolt left to put back in.View attachment 54810View attachment 54811View attachment 54812View attachment 54813View attachment 54814View attachment 54815View attachment 54816
more piece work today got all the black stuff done but the hood hinges. with 2 hinges left to go to. the bolts we are just peeling off the Scali with the wire wheel. then punch holes in the cardboard to mount them and get the paint on. didn't have any luck with parts today. only a couple will pick over bodies out their mostly newer stuff. might need to run up to Sturges. got a yard to check in rapid yet. IMG_3228.JPGIMG_3229.JPGIMG_3230.JPGIMG_3231.JPGIMG_3232.JPGIMG_3233.JPGIMG_3234.JPGIMG_3235.JPG
Ed, a word of caution about that alternator and regulator. Be extremely careful when wiring the car; unplug the alternator and regulator from the electrical system. There are no parts available for that alternator or regulator, and no one even knows how to work on them anymore. They were only used for 4 or 5 years and are extremely complicated to repair. The old fellow I used to have repair high-output alternators has retired, and you had to twist his arm just to work on that alternator. The perforated case is integral to the fields, epoxyed in place, and not replaceable. The diodes are no longer available, and even if you had one, you would need special tools just to replace them. The armature is also unique to that alternator. I had one NOS spare, and I traded it to a fellow at Carlisle only because he needed it to complete his restoration.
got to us up some of the new parts finally but not without modifying it. glad I cut things off the other support before I took it out to my friend's yard. this ambulance with AC has the 4 core radiator in it. the mounts on the new support were for the smaller one. so, we modified it to work. then ran out of o2 before we got both sides tacked on. but in we are and that's what counts. right now, we can move it if we need to. been raining all day here temps in the 40s. no white stuff yet but it is November. DANG ONE MORE CLOCK TO RESETIMG_3236.JPGIMG_3237.JPGIMG_3238.JPGIMG_3239.JPGIMG_3240.JPG
will my search for a local inter fender is a bust. the one we need was out there but badly wrinkled so let's use up some of this gas we brought and brass rod and fix both of these. the main damage is the trap of the hollow brace. and the left side with the battery leaking. right has just a start but we will need to use up some of the trimmings for the left one. all we need is the front edge to bolt to the support. so that's easy enough to do.IMG_3241.JPGIMG_3242.JPGIMG_3243.JPGIMG_3244.JPGIMG_3245.JPGIMG_3246.JPG
more fun creating stuff out of rust with scraps. we have it solid all the holes drilled and ready to get ready to paint. I would be more along but my Nabor across the street brought me supper and showed up a little earlier than I normally stop. what could a man do but enjoy. I finally went and dough out some long spikes I had to tie it down to the sawhorse. got tired of chasing it around justIMG_3247.JPGIMG_3248.JPGIMG_3249.JPGIMG_3250.JPG to work on it.
getting tired of these inner fenders. nice we are about done. decided soap and water are the best bet at this point. tried to sand the one and just two mush stuff caked on them. the were undercoated at one time, but most of that got beat off. I need to clean them off to get to the rust for the converter to do its job sow was with a scotch pad we do. the right one took about a two hr to repair not two days. that was better we paint tomorrow. finished out the day striping out the used door we got. lot of stuff in the bottom of it. we were getting a good conversion on the surface rust on the right side before we rolled it over for the underside. wash them off tomorow to kill the converter and remove it from anything still painted or bare.IMG_3252.JPGIMG_3253.JPGIMG_3254.JPGIMG_3255.JPGIMG_3256.JPGIMG_3257.JPGIMG_3258.JPGIMG_3259.JPGIMG_3260.JPGIMG_3261.JPG
