1969 Stoner Ambulance
took the 72 up for my appointment varied the speed according to instructions put 220 miles on it got 8.6 mile to the gl at 5 bucks a gal. be glad when we get the 600 on it. the Ram is getting 21. but got back in time to finish up the upper seam and find the other dents in this panel we'll have it in filler tomorrow.IMG_4980.JPGIMG_4981.JPG
finally got the rear patch nailed on. the wheel opening came out good in spite of being a inch back from the wreck. now for a little mud. got the start on the front dog leg. we will need to remove the rocker to get that piece in pace. and the front rocker to get the center on in place. the all share a seam IMG_4982.JPGIMG_4983.JPGIMG_4985.JPGIMG_4986.JPGIMG_4987.JPGIMG_4988.JPG
more fun the teardown just brings out the kid in you we got the rockers removed and the filler completed except for around the backup light need to work that down a little more. stripped about have the panel. a lot of rust damage on the right cowl drain inside and out. inside is still solid nothing rusted threw. bet you can't figure out where we got the patch panels for the rear pillars. we'll see if we can get the dog leg on tomorrow. IMG_4990.JPGIMG_4991.JPGIMG_4992.JPGIMG_4993.JPGIMG_4995.JPGIMG_4996.JPGIMG_4997.JPGIMG_4999.JPGIMG_5000.JPG
finished up the back half and got it in primer. first thing we did before going down to see Kandy was to get the rust-IMG_5001.JPGIMG_5002.JPGIMG_5003.JPGIMG_5005.JPGIMG_5006.JPGIMG_5007.JPGmort on so it can start working. we'll wash it off the places that don't have rust tomorrow. mean time got a start on the dog leg. this rig has been worked over but not completely. the top was resprayed, but the body just spotted in here and there. this quarter had one coat on most of it except the lower front of the rear wheel well and this spot behind the center door
just to be sure and because I forgot i did it once, we wiped the panels down with a scotch pad and water. the blew them dry. then commenced to trim the doge leg and fit it in place. the smaller panels are more of a pain then the little ones. but we got it fit into the hole and made it part of the rig. a little grinding a tug or two and we slapped some filler over everything and test fit the rocker. looks like a little cleanupIMG_5020.JPGIMG_5021.JPGIMG_5022.JPGIMG_5023.JPGIMG_5024.JPG and a rubber hammer it will fit
must have been tired last night forgot to hit post again. will today offered some explanations. I discovered that no one has a right front rocker for the 67-72 suburban. they don't make one. I laid this pickup one in the hole, it fit front to back. I miss the around the center pillar. guess who put the one he cut off in the trash bin? yesterday was pickup day. we had to make one. man, I sweated that out for a bit. glad I didn't take it off 6 months ago. don't toss anything before the job is done. rockers are on front and back sill got to do top and bottom and the dog leg is in primer. I thing I got as much of this rig outside as I do in! IMG_5026.JPGIMG_5027.JPGIMG_5028.JPGIMG_5030.JPGIMG_5031.JPGIMG_5032.JPGIMG_5033.JPGIMG_5034.JPGIMG_5035.JPG
got a little more done. still got to get the bottom tacked down but I got it straight at least. need to get up to the welding supply house and get some longer sticks of brass. these short one burn up to fast. that' all we have in town now. not a lot of people using them now with the wire feeds out there. but since I can't use the wire feed any more it old fashion. someone needs to take it apart again they will cuss me good. did get the top in. we need a filler piece in between the two haven't decided one what to cut it out of yet but looks like the dog leg piece is the best. nothing just that shape in anything. did get the other tire off, so I have started on the other side. somewhat. the fold ground down nicely only one pin hole in it.IMG_5036.JPGIMG_5037.JPGIMG_5038.JPGIMG_5039.JPG
glad to get this side on finely. get it cleaned off and primed tomorrow. the plug came out OK we will use seam sealer under it to fill the crack got the pin hole in the courner ang the rear flat on the center door. things look good underneath oly surface rust. IMG_5040.JPGIMG_5041.JPGIMG_5042.JPGIMG_5043.JPGIMG_5044.JPGIMG_5045.JPGIMG_5046.JPGIMG_5047.JPGIMG_5048.JPG
took the day off yesterday to swap valve cover gaskets on the 67 and put in a used fuel gage. turns out the new sending unit is bad. had to paint the covers but the gm corp blue they are is out so back red they be. we'll do the rest one part at a time.
but today we got back on the stoner. finally got this in primer on the right side. been looking at a knot on the lip of the wheel opening so checked it out. glad I did we had ground threw a rust spot and raping the lip opened it up. got it glued back together and cleaned up. worked the panel over with the long board and 180 paper to check for high spots or any hallows. found one low so we filled it and attempted to spoon down the few High but turned out they were where the floor rests, spot welded on to the outer skin. don't thing I moved them any. IMG_5049.JPGIMG_5054.JPGIMG_5055.JPGIMG_5056.JPGIMG_5057.JPGIMG_5058.JPGIMG_5059.JPGIMG_5060.JPG
Back at it today. Filled the seams on the right and wiped off the excess. Noticed we missed the hanging-down portion of the rocker when we primed it. We'll get it next round. Started the quarter on the left. Someone beat me over here also. I wondered why I couldn't find the body line on the unit on the panel. Someone got creative with the mud and made a new one instead of ironing out the original. A little more rust over here, but nothing we can't remove.
had to make a decision on the rear as the wrinkle is above the body line. the rust goes about the backup light. we'll have a different cut going on this side. got things ready to attach then we coated everything with the Rust Mort. I'm hoping to get away with laying the back up mount in the void loose. so we can get behind our seam. it's a blind void so we can't reach in thew to put it in place IMG_5074.JPGIMG_5075.JPGIMG_5076.JPGIMG_5077.JPG
It's now or never to get this panel on. I'm not going to comment on the man that cut the new piece right one the line for butt welding, except to say it's hard to get good help. we just cut a strip to use as a backup plate and tacked it on the original. give us a little more work but make the panel a lot stronger. we got the rear welded in place I'm not going to admit I don't remember the last time I gas welded something. but we got it successfully together. we'll get the long run glued in tomorrow and some filler if we are lucky. there is some problem with the door frame on the very end under the floor. we will have to get creative on filling the void to keep the water out of the quarter. it's not load bearing down low, but it's no longe a solid box. and water can get inside threw it. it got in threw the top and made its way out the bottom. we got the backup light housing cleaned up and redrilled it had only one screw holding it on. repaired the inerpanel were the crunch damaged it. right now, there is not getting it back off but it's just not all onIMG_5078.JPGIMG_5079.JPGIMG_5080.JPGIMG_5081.JPGIMG_5082.JPG
late night for to hit post last night. so today we meet our goal we got the paned solid and covered with mud. tacked the mud flap up were it belonged and tied up that wire for the fuel sending unit. that bugged me. it hund down a foot under the tank. made a decision on the hole we have to plug it as mud and water will go into the quarter. so, plug it we will. got a start on the next panel looks like it got into the same problem the other one did. it threw up front and had a rust hole pushing the filler out. om the back side is a spot ate into the panel with only a pin hole threw. funny none of the holes drilled in for the "repair" show any problems. look at that factory joint? I think we can do better, at least I hope so.IMG_5084.JPGIMG_5085.JPGIMG_5086.JPGIMG_5087.JPGIMG_5088.JPGIMG_5089.JPGIMG_5090.JPGIMG_5091.JPG
wore myself out today tried to cut a fingertip of , not to worry it wasn't my special finger. but did get the first layer of mud knocked down, the left side striped and the remaining panels off. the masking tape is still holding on my finger. the air hammer jumped out of the cut and my hand hit the panel. not the first time but didn't like it the last time either. got another ton of rust and dirt out of the front pillar. and the lift side has a hole threw the kick panel. small but there. cleaned up the mess on the floor and coated thing with the rust mort. this side the front rocker was the last panel laid on the side. we had to get it off to remove the lower piece of the center panel. now real surprises here a little more rust on this side then the right. we still need to clean up around the gas filler, might use that small handheld sand blaster to do that. one way to check if your 17-72 burb has been worked around the wheel well is if the grove is on the lip. most people just fill it in and bevle it off rather then form it.IMG_5092.JPGIMG_5093.JPGIMG_5094.JPGIMG_5097.JPGIMG_5098.JPGIMG_5099.JPGIMG_5100.JPGIMG_5101.JPGIMG_5102.JPG
more grinding away and having fun today. didn't even hurt myself. got the panel striped and sand blasted the filler indent, had enough so we got the sharp ceases at the bottom of the rear doors and inside the light indents. rough out the inner rockers and cleaned up the rust hole in the kick panel. the sanded the filler in the rear and laid some primer down. that hole in the kick panel will take some thought. it will take a piece added in to fill it. there just not a easy place to work. but first things first let's get that pile of dirt out of here. IMG_5103.JPGIMG_5104.JPGIMG_5105.JPGIMG_5106.JPGIMG_5107.JPGIMG_5108.JPGIMG_5109.JPG
it's Monday so we got the hole in the kick panel patched and cleaned up the door jams so we will be ready to prime when the panels are in place.
GM uses a layered-on seam sealer between everything. it's oil base so when your using heat around any joint you got fire in strange places. did our best to keep it under control. but patch we did. 180ed the rear panel and reprimed it before leaving. see if we can get the center panel in place tomorrow. the hardest thing today was cleaning the glue off the sill on the rear door that the nonskid was stuck down with.IMG_5110.JPGIMG_5111.JPGIMG_5112.JPGIMG_5113.JPGIMG_5114.JPG
got back to work today. trimmed up the panel got some holes drilled and put it on. still got to down the down legs and bottom but it's not going any were now. that's a long run to heat up and braze. primed and painted the down braces hoping to cut back on the rust back. IMG_3124.JPGIMG_3125.JPGIMG_3126.JPGIMG_3127.JPGIMG_3128.JPGIMG_3129.JPG
