My initial thought reading 'roof trim strap' is the Crown molding. As you have an ambulance though... Can you provide a pic of the piece you're referencing? There is a '67 Crown parts car near Austin that I've posted before.
are we talking about the 3 piece aluminium trim that sets just in front of the raised portion of the roof under the lights? what is it your missing on yours?
see it now. yours I take it did not come with one. it about a 1 inch wide 1/4 in thick piece of aluminium that is polished. the edges have been rounded so they not a sharp edge.
if you can find one to get the with and the spacing for the screw holes it would be a easy make up. I would think it is in three pieces with the center strap about two inch in from the edge of the roof. they use a number 10 screw on this 63 to hold it in place. we had the man in St Paul plate it for us.
as there is nothing but head liner under it be careful drill the holes and use a dab of sealer on each screw.
