considering that there are 2 terminals broken off of it, my best guess is that someone used it to connect the wires together. To verify my thoughts, check the connections between the terminals with an ohm meter when the battery is disconnected and the wires on one terminal are removed. If it is a Delco relay, and there is a part number on the relay, you might be able to determine what it originally was used for. The problem is that the bodybuilders were extremely sloppy electricians, and their ways were very unorthodox of where they took power from and where they sent it. I don't believe that this is a factory item since it doesn't have factory-type connections.
