http://www.ebay.com/itm/172182608355?forcerRptr=true&item=172182608355&frommaketrack=true&viewitem=
1966 Cadillac Combination (Parts Car)
"Hearst"
"Here is acool Cadillac Hearst for fun to fix up and drive or use it for your business, maybe a camper or a street rod, it could used for anything. Of course the car has the big v8 engine and the car is complete and all original. I pulled out of the weeds, changed oil filter, greased it, dropped the fuel tank, cleaned it and sending unit, replaced all fuel hoses, fuel pump, cleaned and kitted the carberator. Replaced ignition system, plugs and wires, all filters Started and run , after the lifters all pumped up and it sounds great, serviced the rest of the car and works good. The right rear leaf spring was broken from backing into a solid object and the taillight housing pushed into the fender a little bit. The housing looks ok, but the fender has some damage, but you really cant tell. I found a set of leaf springs in Mass. sitting on a shelf and these are even heady duty original springs. Cleaned the interior, removed front seat to clean, removed floor mats and there are a couple rust holes in the floor. The back of the hearst has carpet and a lot of accessories that come in a hearst. Compartments for lots of storage...This car needs restored the interior has sun damage and water damage from the hole in the windshield, needs body work done and repainted as you can see in the pictures.. There is a bullet hole in drivers side of the hood and the windshield. Does have original a/c system with rear ac and fresh air system in the rear. I have a set of hubcaps for it. The car has 91728 original miles and was used for funerals of course but also a rescue unit in a small sandhills town in western Nebraska... The accessories in the car are a stretcher, gurney , oxygen tanks, fire extinguisher, siren, revolving light missing the lens.. The tires are fair and stay up but I really think you need to trailer this vehicle, The brakes have not been worked on. Like I say this would be a great project car . Good luck and thanks for looking THIS AUCTION IS A NO RESERVE."
"Hearst"
