1953 Packard Henney 3 Way not too bad
It has had a lot of "creative touch-up" work to areas with heavy surface rust, but looks to be a very worthwhile project!
The man is honest with his description of the car. So you know you are to a project. If you could get to ang get it home under 5 you maybe be all right. Those rockers could be made up easily enough. what you don't see is the bottom of the doors. But if you get it expect to get 50 grand in getting it back up
Two things the front doors are standard sedan doors, The rocker panels standard sedan and hardtop (two door) are available today aftermarket.All in all not as difficult as some. Also I have a complete OD setup available.
