  #1
Old 03-17-2013, 10:45 PM
James Fischer James Fischer is offline
Website Member
Groaned at 0 Times in 0 Posts
Default PROPER mounting of Federal Beacon ...
I REMOVED the weak Signal-Stat #378 from the 70 today.....
Who ever mounted this baby, just took the existing toggles bolts and welded on a 2-3" extension...then mounted the light.....it really look like an amature job......we also found 2 "hot" wires ??.......
Now to mount the 184......I want to mount this ONE first before I attempt to mount the TWO on the 72....
My question is just what is the PROPER method of installation....I have seen people just put in the toggles and then play "fishing" trying to get all 3 bolts to line up ...with the motor already mounted on the skirt.....then I saw a post here from Richard Vyse, when he mounted his twin 184's...I noticed he had the skirt OFF and mounted the motor first to the toggles......
Which of these is best or easier ??
If anyone has any diagrams or pictures available that would be great....
Comments and ideas appreciated !!!
Jim
My goal in life is to be the person my dog already thinks I am. ........
1970 Superior Cadillac 54" Super Rescuer
1972 Superior Cadillac 54"
1951 VW Split Window Beetle
1960 VW 23 Window Bus
1970 Porsche 911 Targa
1969 Chevelle SS Conv
  #2
Old 03-17-2013, 10:55 PM
John ED Renstrom's Avatar
Groaned at 3 Times in 3 Posts
just did that yesterday. here is my way. yours of course may be different.
http://www.dropshots.com/jer57747#da...03-16/08:53:40
as for the two hot wires some 4 bulb lights could be wired so that you could shut off two bulbs. it they were running a clear lens and red and white bulbs in inclement weather it may be advantages to shut off the white bulbs
drop in for coffee anytime
The Following 3 Users Say Thank You to John ED Renstrom For This Useful Post:
James Fischer (03-17-2013), Jay Maynard (03-17-2013), Terry Broussard (03-18-2013)
  #3
Old 03-17-2013, 11:53 PM
Website Member
Thank you Ed.....
I am assuming that the crushnuts were already installed on the roof ??
I have to use togglebolts,since the holes are about a 1/2" wide.....I took out the old welded on ones.....what a pain those were to get out .....
I guess just put a washer and locknut on the bottom portion of the bolt with some loctite ??
And since I am also mounting a 184 I now see how to do it properly..Thank you again for the help !!
As far as the 2 hot wires,the little Signal Stat they had was only powering a turn indicator bulb !!!........but who knows what they had mounted before the Signal Stat....it might have taken 2 "hots"...
  #4
Old 03-18-2013, 07:20 AM
Scott Crittenden Scott Crittenden is offline
EMT / PARAMEDIC
Groans: 1
Groaned at 1 Time in 1 Post
If there are two hot wires the car may have had a federal 175 or 176 beacon. Those beacon can run two or four bulbs selected by a two position switch. Or Superrior just ran two hots in case the customer specified that type of beacon.
[B][I]"The scrutiny was more than I bargained for"[/I][/B] Dr. John Jensen
The Following 2 Users Say Thank You to Scott Crittenden For This Useful Post:
James Fischer (03-18-2013), Jay Maynard (03-18-2013)
  #5
Old 03-18-2013, 12:10 PM
no matter what you use toggle bolts or crush nuts or slide a bolt up threw hole you need the jam nut to hold it in place on the roof. the legs is what everything is held on to no matter what light you use. the weld a extension is one way to make them longer. were it doesn't have to look pretty it has to hold.
now first thing before you cover it up is to find what switch controls each hot wire.
  #6
Old 03-18-2013, 02:57 PM
Website Member
Default Next dumb question....
Ok...so I am still trying to figure out how to pull the bulb portion off of the center shaft itself.....it looks like it is pressed on there..??
So I can get the motor base mounted.....
I really was paying attention in class...just missed that part I guess !!!
  #7
Old 03-18-2013, 03:32 PM
EMT / PARAMEDIC
Groans: 1
are you talking about the cast portion that holds the bulbs. There are hex head bolts behind the bulbs. You just need to loosen the ones that directly contact the shaft.
James Fischer (03-18-2013), John ED Renstrom (03-19-2013)
  #8
Old 03-18-2013, 04:21 PM
Website Member
Quote:
Thank you Scott !!!
Came apart like a champ.......
I didnt even see those hex heads......the light has been restored and the silver paint just covered everything,so the the hex heads didnt even stand out......
Thank you again !!
JIm
  #9
Old 03-20-2013, 09:26 PM
Kevin Lynch's Avatar
Kevin Lynch Kevin Lynch is offline
Default There ought to be a law
My observations over the decades is that private ambulance company people and volunteer fire fighters really get into their emergency equipment.
I can't get over the amount of live wires I've found under the dash. My latest project is a '78 American LaFrance. There are 10 toggle switches above the dash. I don't know where they all go, but I found enough live wires in the dash under that console for all those switches. I put red electrical tape on such wires just to remind me for later projects.
Kevin Lynch
Duckett-Robinson Funeral Home
Central, SC
Member: PCS, SPAAMFAA, Florida Antique Bucket Brigade, AACA, FOP, K of C
The Following User Says Thank You to Kevin Lynch For This Useful Post:
James Fischer (03-20-2013)
Similar Threads
Federal 17? Beacon Ray Attila Bethlenfalvy For Sale To The Public At Large 1 10-08-2012 07:54 PM
Urgently Needed Beacon Ray Mounting Gaskets Ron Devies Wanted 10 06-03-2012 10:54 PM
Federal 17 Beacon Ray 12volt $100 Mark Rodgers For Sale To The Public At Large 2 01-31-2012 02:58 PM
Federal 174 super beacon Leo Luciani Wanted 1 10-20-2011 01:01 PM
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
