175 Beacon Rays
Mike Owens
To your knowledge is there any difference in height in Model 175 Beacon Rays, one with a glass dome and one with a plastic dome? Serial #'s 15N72H and 15E69P
The domes should be the same height. But the bases make the height difference, and could be any height and/or trimmed to fit angles. So it's possible that two beacons from two different sources could be very different in height.
you got a glass dome you don't need, I need one for the 53. the only difference in any of the bubble gum lights was the first generation were smaller in diameter.
