Go Back   Friends of the Professional Car Society - Official Website of the Professional Car Society, Inc. > Professional Car Discussion > Emergency lighting and Sirens
Emergency lighting and Sirens For discussion of emergency lighting and sirens as they are associated with Professional Cars. Posting in this forum is limited to PCS Members and / or Site Supporters. We encourage all website users to become members of the Professional Car Society and / or become Site Supporter.
Old 06-06-2017, 02:39 PM
Walter Suiter Walter Suiter is online now
Default Dirty trick #22-137 Corroded wires
When you encounter lovely black copper wire, and you will if you're in a salt area, vinegar will remove the corrosion in short time and return the copper to bright connectable status.
The easiest and best way I've found to treat such wires is to employ the wonderful plastic stem vases florists use on rose stems. The cap pops off easily, dump the water and replace with vinegar. Put cap back on and insert wire to self clean.
Generally the minivases are easier to obtain from Funeral Homes than florists. They are reusable until stepped on.
Old 06-06-2017, 07:12 PM
Kurt Arends's Avatar
Kurt Arends Kurt Arends is offline
Groans: 7
It will also shine up your copper pots & pans nicely too!
Old 06-07-2017, 12:24 AM
kill rust if you have enough of it and you can drink if you want
Old 06-07-2017, 01:35 AM
Be ery wary of vinegar as a rust removal agent. You can pull out an object that looks clean but has only carbon structure with no iron molecules left.
Old 06-07-2017, 04:02 PM
me I don't have enough time to mess with it as with any acid you pest not dump that one year had to find piece in it for any reason. that's what bead blaster are for. they is a interesting vido o Y tube on rust removal. sorry I don't have a link to the one I was watching as I was skimming stuff this last week. but it's safe to say if you have a product you want to try there is a video on y -tub some one has posted using it.
need a rust converter use Coke
Old 06-07-2017, 05:10 PM
Rust conversion is a Phosphoric acid process 5 to 8% in water solution. Phosphoric is the only acid that doesn't attack good iron. Lot of Phosphoric converter is sold by Locktite & others. Add a little dissolved magnesium if you want a nice black color. Go up to 50% Phosphoric and Phosphoric becomes a rust remover.
Do NOT get Phosphoric around aluminum unless you want the aluminum to disappear.
Want to chelate rust, get a bag of cow molasses.
Electroplating rust off is the fastest process that works.
Blasting with any media, other than soda or corncob just peens rust seeds in for future growth followed by coating spall.
Old 06-07-2017, 05:12 PM
you ever read the label on a bottle of coke
Old 06-08-2017, 01:55 AM
A few times. I'm ancient enough to remember old timers polishing golf clubs and bumpers with Coke and crumpled aluminum foil.
There are far more efficient ways than Coke and more cost effective as well.
Tracking down brake wires Kevin Lynch Technical Discussion Forum 3 11-29-2013 08:50 PM
cut wires Chris Elzie Emergency lighting and Sirens 8 03-11-2013 12:49 AM
