The 4 original rubber gaskets that used to be under my Grimes Full-Vu lights are too burned and dont fit anymore on the top. What can be a good replacement gasket? Where can I find it?
The best looking white gasket that fits, but doesn't look like the original is available from John Dorgan, by the foot. You will need about 30" to go around the bottom edge of the light. Other than that, I believe that your choices are limited to what you can find locally for a U shaped rubber gasket.
Good to know, I sent him an email, when I purchased a beacon from him i received this kind of gasket for the Junior beacon, seems a good replacement, thanks!
