What are these called?
Removable vertical part sticking up on near corner of table. Is there a more technical or proprietary term rather than generically referring to as bier pin? I need to find 2/3 matching and don't know what to ask/look for. Thanks in advance.
This is from a Superior manual , I guess they would call it the same?
  • Untitled 1.pdf
Attila
They are revolving bier pins.
They pivot on a camber inside and as you turn them they snug up against
the casket on 3 way tables.
There are also ones that look the same but don't adjust as well.
Very different that the standard end loading 2 bier pins
that are stationary and adjusting.
They are in my '60 S/S 3way hearse.
Darren
Attila
Darren
What is the difference? Does it have to do with the of post in the bottom of the pin? I have seen some that are in the center and I have seen some off center. In my 38 packard they are all of center.
