White wall tire for Hearse
Can anyone recommend good White wall tire for 62 Hearse.
I have been using regular radials Perelli and over the years have have a few complete rear tire blowouts. Always seem to be drivers side rear. Dont think its the rim as I rotate tires
Would like to get heavy duty WW tires.
Thanks
Contact them and tell them what you are looking for. They might even offer a light truck (LT) tire in a radial.
You must keep the tire pressures where they belong, or you will blow out the tire, because it is underinflated. Number 1 cause of tire failures!
https://dbtires.com/
Diamond Back Classic Tires
4753 SC-90
Conway, South Carolina 29526
888. 922. 1642
Suggestion...
That car was built to ride on an 890 x 15 bias ply tire. You can get the correct tire for the car from Coker Tire and I have used them for years and taken long trips without any problems. I even did laps at Bristol Speedway at a speed which scared the bodily fluids out of my nephew. Not only that, they will look better and make the car ride where it should so it will look better.
https://www.cokertire.com/tires/890-15-firestone-3-whitewall-tire.html
So you can see the cars stance on the correct size tire.
Coker tire has four pages of ads plus the back cover in the August Hemmings Motor News plus Lucas,and Universal tire get a copy and enjoy Or just call them they are the largest supplier of tires for vintage rides in the world.
I sure wish these were available with various whitewall designs. I could live with the tread pattern just to get my car's stance/ride height where it should be.
If 890X15 is not available in the ww size I need what is another more available size bias ply I could use?
They offer it in 3 inch WW. Which is correct for the 61. They dont offer it in the dule stripe that the 65 up used.
