a decent welding shop should be able to put that back together for you. ferno was big on using there stuff on about everything so anyone of the folding stretchers would have the same part they only had the two styles of hinges. should be attached with a drift pin but every time you step forward the did that one just a bit different
Unfortunately, you will probably have to buy another complete stretcher to get your part. Not too many folks parting out stretchers these days. Most that are in rough shape just get scrapped.
that would be the problem worth to much scrap to part one out. as I sad any good welding shop can put the eye back on. then it's drill out the hole and grind the backside flat. a little dreamel work and you can make the repair disappear.if you take it apart and just brig in the half that is is broken it may not be all that much money either.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
