I found a switch on ebay for $7.95. Probably any good parts store can still get one of these. 390356543516 is the item number on ebay. This may be the part you need.
The auction that Mike listed is for the canceling cam. Is your switch bad or is the canceling cam broken? Only way to know for certain is to take it apart and look. Be glad that it isn't a tilt telescopic column, because they require specialized tools to take it apart and get it back together.
