Learning as I progress looking to replace missing landau irons on my '60 Crown.
Superior used two different landaus starting in '59, looks like through (at least) '62. After coming up with 3 sets of landaus in the last year, each incorrect for my coach, I began looking more closely and can not fill in all the blanks.
This is the style I keep coming across (which incidentally appear the same as '57-'58 and may be identical):
Each of the sets I've found have come off '59 or '60 non-Crown models and I expect the same was used until '62. (In '63 the design changed.) Initially I thought Superior was using up existing '57-'58 stock but have seen too many post-'58 coaches for this to be accurate. Here is the best representation showing each, both correct, from a borrowed photo (Brady's Crown on right):
So, why wouldn't Superior have used the same landau when new styling was introduced in '59? Did the increased space between C and D pillars on Crowns necessitate a longer (and center to center) landau iron measurement? I've not thought to measure them previously until more puzzle pieces revealed themselves.
