  #11
Old 08-01-2020, 11:45 PM
Peter Grave Peter Grave is online now
Then go to a nearby quarry or place where they sell stone and have a scale have it weighed and find out for sure the real weight. BTW I just got my new issue of Hemmings Motor News and with it came a free catalog from Universal Vintage Tire Co. 42 pages long 1-877-217-4316 or Coker Tire 1-866-708-1268 one of the two with the weight supplied can solve your problem.
The Following User Says Thank You to Peter Grave For This Useful Post:
Ricky Jones (08-02-2020)
  #12
Old 08-02-2020, 10:25 AM
John ED Renstrom John ED Renstrom is online now
I never got one on the scales that went over 6000. Including that 58 euerkia but if its a 3 way? Never ran one of them across the scales. Did you blow on out after you changed. The axal the last time?
  #13
Old 08-02-2020, 12:51 PM
Daniel Scully's Avatar
Daniel Scully Daniel Scully is offline
This is the 75 Criterion weight slip.
Current Pro Cars and Some Others
1961 S&S Limo Style End Loader
1962 Buick Electra 225 Limo (By Flxible)
1965 C/B Landau
1968 Crown Royale 3-way
1975 M-M Criterion
1996 Eagle Coupe de Fleur
1964 Dodge 880 Hardtop Wagon
1973 VW Thing
1968 A-100 Truck
1970 300 Convertible
The Following 2 Users Say Thank You to Daniel Scully For This Useful Post:
Paul Steinberg  (08-02-2020), Ricky Jones (08-02-2020)
  #14
Old 08-02-2020, 01:54 PM
Ricky Jones Ricky Jones is offline
Yes its a 3 way.
Ive never changed the axles yet.
One time when getting alignment the tech said the wheels front to rear not aligned or something and that vehicle when running on the road will look
like its at an angle when viewed from rear by another car following it.
But Ive never Seen any unusual tread wear and he was the only one who ever said that after many alignments.
1962 Cadillac Eureka
  #15
Old 08-02-2020, 02:41 PM
Russell Street's Avatar
Russell Street Russell Street is offline
Groans: 1
Originally Posted by Ricky Jones View Post
Yes its a 3 way.
DING, DING, DING.....I believe you've just identified your problem!!!If it's "doggy tracking" going down the road, you're gonna keep having tire troubles no matter what you put on it!!! Get the tracking corrected first, then different tires.
[B]Proud student of the Limbaugh Institute For Advanced Conservative Studies for over 20 years.
The Following 3 Users Say Thank You to Russell Street For This Useful Post:
Paul Steinberg  (08-02-2020), Rick Franklin (08-02-2020), Ricky Jones (08-02-2020)
  #16
Old 08-02-2020, 02:55 PM
PCS President / Senior Website Administrator
Dog tracking can be adjusted so it doesn't wear the tires, by changing the toe of the car. An indication that this has been done, is the steering wheel is no longer centered. The car doesn't know any better, except that the steering circle in one direction will be wider than the other direction. If you were to jack the car up so both wheels were off the ground, and put the steering wheel in its straight ahead position, you will see that the wheels are pointed in a different direction than straight ahead. If they removed the steering wheel to compensate for the problem, then the directional signal cancelling mechanism will also be problematic on one side. Lots of ways to cheat on the alignment for dog tracking. Just need to know how to do them. Even the correct differential can dog track if one of the rear springs were changed, and the centering pin isn't located correctly on the differential.
The Following User Says Thank You to Paul Steinberg For This Useful Post:
  #17
Old 08-02-2020, 05:06 PM
On the registration shows the car weight as 6820lbs. Even my 59 Cadillac convertible weight shown on reg is 4960lbs.
So just changing the toe on the front end alignment stop tire wear solves the problem? I had leaf springs changed. What should I look for centering pin not correct? I havent seen any unusual wear on the rear tires.
The Following User Says Thank You to Ricky Jones For This Useful Post:
  #18
Old 08-02-2020, 07:41 PM
Rick Franklin Rick Franklin is offline
Groans: 16
Groaned at 7 Times in 6 Posts
any shop that knows what they are doing can do a 4 wheel alignment
........1986 Lincoln S&S Landau Funeral Coach with extendable table...............
The Following 2 Users Say Thank You to Rick Franklin For This Useful Post:
Paul Steinberg  (08-02-2020), Ricky Jones (08-05-2020)
  #19
Old 08-05-2020, 10:25 AM
My standard advice is if you have troubles go to the last thing you fixed. You keep blowing out that left rear and know it dog tracking. Check that set up on that new spring. My bet is they missed the center bolt. When the put it together. That was what caused the failer in the assmbly also.
  #20
Old 08-05-2020, 10:33 AM
We didn't run the 75 across the scale as Robert was driving it back home. But it was a way heavier car then anything else. 7200 for it not the 9000 the last guy told me one waighted. Y can beleve a Eureka 3 way hits 7000. The table has to add a ton at least. The 58 was just over 5000.
Another Tire Q. Dave Hopping Technical Discussion Forum 4 04-20-2017 06:57 PM
Tire balancing Shawn Blyler Technical Discussion Forum 3 06-27-2015 03:29 PM
Master Cylinder Failure Paul Steinberg Technical Discussion Forum 15 06-04-2013 09:15 AM
'77 Rear tire size Josh Rutter Technical Discussion Forum 6 01-07-2013 06:44 PM
time to blow out the 09 dust John ED Renstrom General Discussion Forum 0 12-31-2009 03:57 PM
Powered by vBulletin® Version 3.8.9
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
