Wanted - Lower Fender Molding
Status
Not open for further replies.
I need a piece of trim as indicated in the attached photo for the driver side. It is a 1988 Cad. Please let me know if you have one for sale or the location of one. Thanks.
I'm thinking a "Pull-N-Save" should have these. I know down here we have several Caddy's in the salvage yard and will check next time I'm there.
trim size
My bet is that the lower fender trim piece is a standard size item. Consider that would have been a part probably supplied by Cadillac on the chassis as sent to the coachbuilder.
A couple quick measurments would tell the tale here.
Good luck,
61 MM
should be a standard caddy part. the rocker on that one was made from two fleetwood ones spliced together. or it was on my collins any way.
Cadillac Tim for all your strange needs...
I mentioned to Rocky off-line that I'm using Tim Groves in Iva, SC. (google Cadillac Tim). He's finding some hard-to-find used parts for my 75. Iva is southwest of Greenville.
Good luck!
Kevin
Status
